Power Trim won't Work
caken
Hello Everyone.
I have seen a few postings on here about this but mine is slightly different so I thought I would start a new one.
This weekend my power trim went out. It worked fine in the water and then when I got it out on the trailer and tried moving it a little bit nothing. Now when I try to go up or down nothing will happen. I do not even hear a noise coming from the motor.
I am sure it is probably an electrical problem, but since I am new to this stuff any advice would be helpful.
Bt Doctur
Re: Power Trim won't Work
We would all love to help, it`s just that we don`t know what you have for a trim unit.Go to the adults section and rear the "Read me first" sticky
Ayuh,.... Different,..?? Same Answer,..
Get a Multimeter,+ Follow the Power... Probably a corroded wiring end...
caken
Sorry I don't have the info on what trim unit it is. I told you I was new to this :)
I will try and figure that out when I get home. In the meantime I guess the best option is to follow the wiring back and see if it is that right?
Ayuh,... The Shake & Wiggle Test just might point you to the Problem,...
