power trim motor
lauderman
I have an outboard yamaha motor (I assume 1990's) that the trim motor was corroded and seized up. I purchased a new one but how in the h**l do you get the third mount bolt in without removing the entire assembly as I had to break the old one out to remove it? I can only get to two of the three mount bolts.
99yam40
Re: power trim motor
depends on the motor you have, can you post a model and HP?
On my C40TLRX I pulled the top pin and that allowed the unit to tilt out far enough to get to back bolt.
May have to pull whole unit or just pull motor off boat
