Power Trim Manual Relief Valve
vigilsandiego
On my 2003 Maxim With Mercruiser sterndrive, I have a OILDYNE TRIM PUMP but i can't find the Manual relief valve. Do I need to take the cover off the motor to get to it? I've looked at the manual but it's unclear. I want to verify my pistons aren't frozen stuck.
vigilsandiego
Re: Power Trim Manual Relief Valve
Yea, I looked at that manual but the only relief valve on pdf page 4 looks like you need to disasemble to the pump to get to the valve.
vigilsandiego
What would be the best way to loosen restriction to allow the trim to go up and down freely?
Bt Doctur
Messy ,but remove the 2 hoses from the pump and place in suitable container to catch the oil that comes from the rams when you push down.
RRitt
or from the rams if they are easier to get to or easier to tie a bucket under.
