fin-bender
Thread starter- Joined
- Jun 22, 2010
- 5
Hi, I am new pretty new to the boating world, and have been learking here a bit. I decided to register to ask a question. I have not been able to find an answer.
I have a 1998 Merc 115 2-stroke motor and I was wondering if my tilt/trim is working properly. There appears to be a single ram that lifts the motor. Does this mean that I only have a power tilt system ( and not power trim) or is it some type of hybred tilt/trim system?
Last weekend I was at just over idle speed and tried to tilt the motor up, I hit the up toggle on the throttle and it appeared that nothing was moving. I then put the boat in neutral and was able to lift the motor, it came up quickly. This lead me to wonder if something might not be working properly.
Could some review how the tilt and/or trim works on this motor and how I could do a systems check to see if its working correctly?
Thank you.
Thank you.
