Power steering "skips".
akomar1
Twin Volvo Penta 4.3 GI, Regal 2660.
When I am turning steering wheel, it sometimes skips a 1/8 of a turn and then engages again. Otherwise it works good. Please, advice.
Re: Power steering "skips".
Ayuh,... Is it ever, or always at the same point,..??
My 1st Guess is,.. Your Helm is Shot...
What do you mean by shot?
Ayuh,... Shot,... Beat,... Whipped,... Done for,... NFG....Junk...
This Is a cable over hyd. ain't it,..??
The only place it could Skip is the helm gear against the cable gear...
EddiePetty
....or your belt is simlpy slipping. Check your belt condition, tension and clear of fluids.
FWIW....Ed in 'ol Virginny
Could be slightly low on fluid, too. Ed
akomar1
Sorry, Turkey duty.
I am preatty sure it's cable over hydro.
Going to take it apart tomorrow. Fluid is fine, I added to the level. It is skipping quater turn now, same spot.
havasuboatman
Ensign
If it's cable/hydra, is it rack and pinion (at helm) or is it rotory? If it's R/P make sure the bolts holding the cable (rack) are tight to the helm (pinion).
But that isn't likely. Bond-O is probably right.
JoLin
Yup. Belt first. If slipping it'll cause exactly the symptoms you described.
