Power Steering leak M/C 5.0
rick3452
I was seeing oil in the bildge and trying to find the leak, then while out for a cruise I noticed a "groan" when steering, The power steering resevoir was not regeistering on the stick. I refilled and of course the groaning went away. The question is.... where should I be looking for the leak?? Thanks a million...Rick
Bt Doctur
Re: Power Steering leak M/C 5.0
oil inside the boat= internal leakage, hoses, connections,steering cylinder
no oil inside= power steering cooler
cr2k
Often where the lines connect to either the steering actuator near the rear of the engine starboard side or at the pump.
Ayuh,... The Whole P/S system consists of the Pump(on the motor), the Hi-pressure line to the Actuator(at the transom), 'n the low-pressure line to the Cooler(usually under the portside motor mount), then back to the Pump again...
It can be leaking at Any point, ya just gotta Look...
rick3452
Thanks very much.. I will post back when I find it.
rick3452
Still loosing fluid and I have traced the lines from the pump to the back of the motor, everything seems dry??:confused:
redjmp
Lemme guess, your boat is raw water cooled and run in the salt?
That would point to your oil cooler...
rick3452
Correct!! Now dumb question....where is oil cooler:redface:
Also can I use ATF in the power steering system to help find the leak,
being red??
Don S
If you traced the lines from the pump to the back of the boat, then you had to pass the cooler on the way. Should be on the back of the engine. Trace the water hose from the transom shield to the engine, it's the first thing to see cooling water.
Ayuh,... As noted by Don, ya couldn't have looked very hard,...
The Cooler is in the return line back to the pump...
rick3452
OK found it!, The hose clamp was a little loose and I had oil on my fingers under that location, Tightened it up and we will see.....
Thanks, you guys are very much appreciated..
rick3452
Can I replace the oil cooler myself?? Any special tricks?
2000 5.0 Mercruiser closed cooling system
Nope,... 4 hose clamps, 'n the mountin' bracket....
rick3452
Thanks Bond O.... Just give supplier Engine Serial number?, Or measure size of cooler...
Ayuh,... I ain't gonna say they're all the same, but there's danm few differences....
Order by Serial #, 'n you can't go wrong though...
rick3452
Thanks again, I'll try to order one tomorow....
rick3452
Replaced Oil cooler today, and all went well......... Thanks!
