power pack coil wires (Top Plug)
johnmark
I have an 1983 johnson 50 hp (J50BELCTA) I just installed a new power pack and new coils trying to find out which wire goes to the top spark plug. And what would be the result if they were crossed? Thanks, John
johnmark
Re: power pack coil wires (Top Plug)
I see three wires from power pack, one to kill switch; two to the coils, a orange wire ,and a orange wire with a stripe.which to top coil ? Thanks again guys,John
F_R
Honorary Supreme Mariner
The diagram that I have shows orange to the bottom coil and orange with blue stripe to top coil. If you cross them up, it may backfire and won't run because it will be firing at the bottom of the stroke.
johnmark
Thank You; I found a diagram in a old seloc manual it was hard to make out ,I have the connector pinned but both coil side wires were orange I just wanted to make sure I placed the striped one on top. and she fired right up and is running fine on the muffs. thanks again , John Mark:)
