I applaud you for chasing your dream.
I once thought about doing something similar with classic cars. I enjoy working on them, did some work for friends and thought I could develop a business doing it.
One thing I would worry about is insurance. I hate insurance, but what if someone has an issue with your repairs or gets hurt after you worked on the motor? It might not be your fault at all, but in this sue happy society, you never know.
Maybe you would need to have an LLC designation so you can't be sued personally.
Think about hazardous waste costs. Old oil, etc.
You have to charge enough for unforeseen problems. What if you strip a thread, a ceased bolt breaks off, crack a case while trying to remove it or the many other mishaps that can occur.
When I did my bellows job, there were a couple unforeseen things that needed attention. Seals, shift shaft bushings, plastic bulkhead fitting snapping off, removing stubborn bolts. There was one that I had to drill out, then pick out the remains without damaging the internal threads. If I hadn't been careful, I would have had to spend big bucks on a new part. It was quite time consuming, but it was mine, so I didn't care how long it took.
If you're doing this at home, will your neighbors complain?
That being said, I personally prefer small independent repair shops. They are usually more down to earth, charge less, more willing to explain what has or what was done. Basically more personable.
I wish you luck in your endeavor.
Let us know how you make out.
