Cat-A-Tonic
Thread starter- Joined
- Jun 11, 2011
- 10
New here... I'm sure you get a lot of these but here goes. Any help is appreciated.
I own this boat:
http://www.g3boats.com/Angler_V162_T
Mine is a 2009 model, but you get the idea. Aluminum Deep-V, wide body. Don't know the exact weight, but it has to be close to 2000 pounds give or take. I bought it used. It came with a 2009 Yamaha 60HP 4 stroke.
This thing is a dog. Zero hole shot even with it lightly loaded (just me and my 10 year old and our fishing stuff), takes a long time to get on plane, and won't get above 24 MPH @ 5100 RPM's at that loading. When loaded close to capacity, the boat will not get on plane at all and the best it will do is 9 MPH @ approximately 4200 RPM's.
The prop is an aluminum 10 3/8x13. I don't know the manufacturer, but I suspect it is a standard Yamaha prop. Stamped on the inside is 10 3/8x13-G. I have no idea what the G designation is.
The motor is mounted to the transom in the lowest possible position. The only way to adjust is up. The cavitation plate is just about in line with the keel...maybe a tad lower.
I think I have a prop with too much pitch and/or the motor is mounted in the wrong position. I don't know squat about boat setup, but it seems to me that I should be getting better performance in terms of both top end speed and engine RPM's out of this boat.
Any suggestions are appreciated. Cheers...Jim
I own this boat:
