polyurethaning before fiberglassing deck
bprz09
I am not sure if this is OK or not. I know the person who had put in the wood for the floors of my boat put 3-4 coats of polyurethane on the wood. The wood is down and I am ready to re-fiberglass the floor but I am not sure if this is OK or not because it may interrupt the setting of the fiber glass. I did search around for this topic but couldn't seem to find any info on this.
Thanks in Advance!
bprz09
Re: polyurethaning before fiberglassing deck
I also believe it's regualar grade 1 plywood with 3-4 coats, I'm feeling this is a bad idea before i start putting down the fiberglass.
tpenfield
No polyurethane for you . . . you should glass right onto the wood for good adhesion, etc. The resin will do the same thing as polyurethane and a lot more.
jigngrub
If the urethane is already down you have 2 options.
1. Sand it with some 100 grit to roughen the surface for bonding purposes.
2. Sand the urethane completely off.
bprz09
Thank you so much for the advice! Now I atleast have a better understanding but now do i use a Epoxy Resin or a Poly Resin because from everything i've read and if i were to sand the wood down, the Poly resin won't set as well as the Epoxy bc it's already painted with polyurethane.
jigngrub
Go with epoxy, it's much stronger than polyester.
