Pole conversion
SweeperForce
Hello,
There has been a little chatter in here about converting a 20 pole alt to a 12 pole. Has anyone made any head way? I am so tired of searching for hours on end looking for a tach for my 20 pole stator. I also am getting conflicting info from different venders. My life and the lives of other people in here would be better if we could all be able to install a 12 pole tach.
Tom
jason32038
Re: Pole conversion
Sweeper go on ebay and in search type in tachometer...when the next page loads with the tachometers type in Faria US Marine in search. Or click this link.. http://cgi.ebay.com/ebaymotors/FARI...1355324QQptZBoatQ5fPartsQ5fAccessoriesQ5fGear This guy is selling new in box 12/20 pole tachs from 94'. Also has matching speedos and I believe these match the Faria Nantucket guages. I'm ordering mine soon so dont take them all.
Frank Acampora
Re: Pole conversion
Sweeper: Assuming you have a late Chrysler or earlier Force prior to installation of the Mercury style ignition, there is a Chrysler factory conversion. This was offered when Magna-Power II ignitions started failing regularly.
However, it is costly and complex, and you need to hunt up the components. It requires a 12 pole alternator stator, special stator mount (of which few are available), distributor, Motorola CD box and coil, timing tower, and Motorola regulator/rectifier. Ignition switch is the same but must be wired differently.
All in all, not a conversion you would do just to install a tach because you like the design. better to settle for what tachs are available or try to swap the tach guts into a case and bezel you like.
jerryjerry05
Re: Pole conversion
Sweeper,I tried to send you a PM about a tach I have.You won't accept PM's.J
rickryder
Re: Pole conversion
Might be a dumb question but how can I be sure what tach goes with my motor? 76 55HP 577HG ?
SweeperForce
Re: Pole conversion
Sorry Jerry, I didn't relize I disabled PMs. I turned the PMs on, so if you could be so kind to try it again.
Tom
SweeperForce
Re: Pole conversion
Thank you all. I had no idea how difficult it would be to convert to twelve poles. Thanks again for all the replies.
