PM9
Thread starter- Joined
- Jul 11, 2010
- 31
Hello all,
I've spent a couple of hours on this forum and found a lot of very interesting information...hopefully, I can get an answer to my question as like with most of you, I found there are not too many mechanics out there that know anything about these motors...even certified Mercury dealers..!!!
Here's the deal, I'm not a mechanic but I am dealing with a friend that know's his way around boats.
I just recently made the acquisition of a Sea-Ray Barracuda 1994 with a Sportjet 90 engine. This boat hadn't been running for 2 years.
After making the usual tune-up and inspection (check the impeller, clean all the carbs up, check battery, lubricate linkage and changed all 3 plugs to new ones), we checked the compression...140psi on #1, 145psi on #2 and 145psi on #3...all good so far!
Time to bring it in the water and there is where we found a problem. The boat had a tough time coming out of water and once it finally did (after having my friend sit at the front end), it would only get up to 20 mph at top speed. My friend took a look at the motor and the spark plug from the bottom cylinder was wet indicating this cylinder was not working, hence the motor was running only on 2 cylinders.
Here's my question, what's the next step and is this something one of you have seen with this motor??
Serial number is # 0E034610
Thanks in advance,
Pat
Thanks in advance,
Pat
