plug wires for 1984 Johnson 115 model j115tlcrd
brucehick
Away from the boat and would like to grab a new set online prior to the weekend but I am not sure of length or type. All suggestions welcome
emdsapmgr
Re: plug wires for 1984 Johnson 115 model j115tlcrd
Bombardier sells plug/coil wire sets in a kit. Comes with the precut special wire, boots, terminals, instructions and some grease. 582365. You need 4 pcs.
Chinewalker
Out of curiosity, why are you replacing them? Barring critter damage, corrosion or other actual physical damage, they really don't go bad.
schematic
CDI makes very nice wires for the crossflow. part# 931-2365
Best I've seen.
brucehick
Best I've seen.
I am replacing a couple that look pretty beat up. I thought it was time since they have been on the boat since 1984. I also thought that changing them was a good maintenance procedure. Thanks for the part numbers
