Please help with year of 70hp evinrude.
cootshobbyfarm
I need help determining the year of my 70hp evinrude. There are no numbers on it anywhere. Thanks
Honorary Supreme Mariner
Without a picture I can tell you they were made from 1974 to 2001
cootshobbyfarm
I've got pictures just cant figure out how to get them on here.
cootshobbyfarm
Did this work
WernerF
- 56 cu in.
- VRO model, but non-VRO fuel pump inside
- rectifier, no regulator
- no quick start
- tell tale off exhaust side
- PTT relay box on top
1986...1988
cootshobbyfarm
Man I appreciate it wernerf. Now if you dont mind. Whats vro. And is it supposed to have a rectifier? Also whats quick start? Thank yall so much
WernerF
All these things are engine features that came with the years and now let me distinguish between them.
VRO = variable oiling ratio. That is a pump mixing fuel and oil together. Someone removed it from your engine, so you have to premix oil and fuel 1 : 50.
Your engine is supposed to have a rectifier for charging the battery. That system needs an old style non-maintenence-free battery which can withstand some amount of overcharging. Voltage can go up to 16V. Later models have a regulator which prevents overcharging.
Quick start is a feature of younger models. It raises idle rpm on cold engines.
