jgresham75
Thread starter- Joined
- Aug 19, 2008
- 70
Engine locked up while out today. Would not turn over. Came home, pulled plugs and water came out.... Now what do I do? Boat has been running fine all summer. Put new GM long block in two years ago. I always pull my manifolds every year or so and check for thin walls, anything that could cause a leak. Took boat out today and ran fine for a while for about 20 minutes, stopping and starting. Turned it off to change skiers and wouldn't turn over. (I do know not to go into reverse when going forward.) Fearing the worse, I got home, pulled the plugs and water came out both sides. I will find out what happens later. Boat sat with water in chambers for about 4 hours until I could get towed back to dock and get back home. But now, my biggest concern is how to save my motor..... I pulled all manifolds, pulled the plugs and turned it over. Now what should I do to ensure the engine is not totaled? Please help me. I will be following up several times today. Thanks in advance.
