please help punk kids stole prop!!!!!
zrenison
i recently bought a 1986 bayliner capri 2.3 volvo -penta the stern drive plate says its a 275.. but i haven't found any same model w/ the 275.. anyway somebody stole my prop i have no i dea what i had, long/short, right or left pitch, size please let me know what is factory, or the best.. its a 19' by the way thanks
bear_69cuda
Re: please help punk kids stole prop!!!!!
My 19' Bayliner 3.0 L Mercruiser had 14.25 x 21"p for a stock prop. WOT @ 4800 rpm...
zrenison
do you think it should be the same or pretty close to what i need? what does wot mean???sorry thanks... oh yea what about when ordering is it a long or short shaft left or right what ever that means i know it asks for some props
Blue Crabber
Ensign
WOT = Wide Open Throttle
You want to run the engine at the manufacture's suggested wot throttle. If not you will be lugging the engine which is not good for it. (Carbon build up, etc.)
Long / Short shaft applies to outboard engines not sterndrives so you won't need to worry abou that.
It should be a standard rotation prop. Normally you only get into left hand rotation props with dual motor setups. (These are the most common situations, not that there are some others but i don't have as much experience in that area)
Sorry that I can't help you out with the diameter and pitch, I am sure someone else will be able too. Just though i would try to answer some of your other questions.
Good luck!
zrenison
wow thanks for the info hopefully someone does have in fo i need on exact model but all info helps thankyou
zrenison
BUMP!!! still looking for a prop??? can anybodt help with same year and length, vovlo wont help me they say to contact a dealer, and the dealer jus says let me get back to youand never call back.... figures since i didnt buy from them..and all the websites i have read say a hundred differrent things jus curious what people have on there 1986 bayliner aq131 4 cyl 19 foot
thanks
windsors03cobra
When I bought my prop on iboats the store just asked the make and model and gave a pitch choice or 2 and off ya went, about $125 for a Solas Alum. :cool:
