Please help, outdrive leaking where it bolts to hull/transom
drtjnky
I have a 1989 Bayliner capri 21' with a 5.0 and omc outdrive. I started taking on water and found out that where the outdrive bolts to the back of the boat it was loose and was letting water in. So we temporarily tightened the bolts and put some rtv to seal where the outdrive meets the hull. I need to find out if/what kind of seal and how to replace. Any help is greatly appreciated.
Also where can I look on the boat and online to find out my exact model and info for ordering parts? Thanks again.
Don S
Re: Please help, outdrive leaking where it bolts to hull/transom
Your transom is rotten, and needs replaced. Lots of information on the transom repair over in the restoration forum.
