Please help Front Control Panel 84 dynatrak
astrokc8
Could someone tell me how the front panel swiches work I have the toggle for 2/12 charge 12 volt/24 volt and run. Also I have the 2 12 volt marine batterys on one side and another for the motor. My question is about the 2 12 volts they both have connections for each battery once you hook these up if you flip the toggle to 24 volts does it switch the voltage to the tm to 24volts?
Also does any one have a boat manual for this boat I would love to get one.
