Please help - Engine Compartment won't open
MyOpinion2U
I have a 1988 Mach 1 spolier. The battery got discharged and the engine compartment is opened with a toggle switch. I can't jump the battery because the battery is inside the engine compartment. I tried jumping the wires on the switch together and connecting it to a battery jumper but still won't open.
Wingedwheel
Re: Please help - Engine Compartment won't open
You may be able to use a jumper by hooking up a charger to the toggle itself.
Stamey
You don't have an access hole above the jack/ram that hoists the cover? My Wellcraft has one and you can reach in to release the jack from the cover so you can lift it.
If you are getting 12v to that switch and completing the circuit properly, it should lift. If it doesn't, you probably have a solenoid that the switch controls to send battery power to the lift motor/pump.
If this is the case, you will need to power up the entire system in order to get it to lift. For that you will need to get under the dash and find the biggest black and red wires under there and hook them up to a battery. In theory, the largest wires under there should be feeding 12v battery power to everything in the dash, and there should be a comparable ground in there as well. The red wire will likely be going to the fuse panel. The ground could be connected as a separate circuit on the fuse panel, all by itself, with a bunch of other black wires running to it, of it could be on its own block someplace else, but still in the vicinity of the fuse panel. This should send 12v back through the system and even make the switch work as well. This should definitely be enough to get the cover raised.
Alternatively, are there any hinges you can get to and take loose so maybe you can get under the cover enough to hook up some jumper cables?
Once you do get in there, you'll want to make provisions to be able to prevent this from happening again. I suggest you install a couple of battery cables in there that you can run into the passenger area, perhaps under a seat, and tie them off far enough apart that they can never contact each other, then you'll have a place to connect jumper cables in the future, should they ever be needed.
Chris
MyOpinion2U
Thank you so much for the reply. I actually tried jumping it buy the dashboard but the battery was so low it would not open. I just forced it up and screws on the mount came off.
AZSenza
My Larson also has an access port next to the ram, I've had to use it a few times! I also have a control pad next to the hole that hase Jumper cable attachmets to power the sundeck. If you dont have an access port, put one in , 10$ and cutting a hole! It can save a trip!
