First thanks for welcoming me to this forum. I hope that I will be able to contribute to other boaters but for now I have a issue I can not resolve.
When I have power to the boat and turn on my Nav lights the battery voltage meter drops to 0 and my fuel gauge pegs out past the Full indicator. When I turn off the Nav lights everything returns to normal. Okay well here is where it gets strange. Having the Nav lights OFF and operating in a idle forward or reverse all the gauges work as they should. However, keeping the Nav light still in the OFF position and accelerating to above 10knots the fuel gauge pegs out past Full and my voltage meter drops to 0. But then my anchor light turns on! When I idle back down - the anchor light goes off and my gauges return to normal after a moment at idle. None of this makes any sense. I am lost on where to begin my hunt.
As I am typing this I just noticed my forward Nav lights do not turn on either manually or when the throttle is engaged above 10knots but the anchor light does. Is the problem only with the Nav lights on the bow of the boat?? This does not seem plausible to cause these variety of issues both under power or not. Someone please HELP!
Another thing I have noticed the gauges or switches never illuminate under any situation and I see by the wiring they are tied to the Nav light switch. There does not seem to be a ground wire at either end of the series to the switches that is attached to a primary ground. The black ground wire just runs between the switches but does not connect on either end to a grounding point. The gauges however are. Is this the problem?? I do not want to start rewiring the boat without getting some advice
Boat Sea Pro 180CC with Yamaha 115 4stroke
Thanks so much in advance!
