PLEASE HELP..60 HP Evinrude new impeller not pumping water???
MP1
Have a 1970 Eviunrude 60 HP New impeller has been installed (correctly) seals and water pump, pump housing all in good shape....thermostat has been checked looks new...all lines have been checked for blockage...cannot get the motor to pump water.....motor starts and runs fine , spark plugs were pulled after running to make sure water not in the cylinder all good..water is getting to the thermostat..can anyone help as to what to look for or a solution. greatly appreciate any advice! (the lower unit was taken off three times to double check that everything is put together correctly)
Thank You
Daviet
Re: PLEASE HELP..60 HP Evinrude new impeller not pumping water???
How are you running the engine, on a hose or in a barrel? With the lower unit off and the thermostat out, attach a hose to the water tube and check the flow through the block. If you have good flow, you might check the head gasket. It is possiable for a head gasket to leak compression into the cooling system and cause it to overheat.
emoney
Seems like if water was definitely getting to the thermostat (assuming you had the cover off?), then it wouldn't be in the lower unit, so no sense taking it back off. Is the motor still getting hot, is that why you think the impeller isn't pumping? Or is there a tell-tale on it that's not showing water? Daviet is THE man, so follow his advice as he's helped me over the years. I'm just one of the "extra question askers" around here, lol. Welcome to iboats, btw.
