Plastic Tubing going to exhaust??
Rick L G
My 1988 125hp force motor is puking water out a cracked exhaust tube to goes directly to the exhaust holes on the back of my motor. (I obviously don't have the correct terminology for this part) I've searched my diagrams and they seem to skip the area from the motor to the lower unit entirely. The "exhaust tube", which has a coil in it, is cracked compeltely through and once I was able to access it and remove it there was a plastic tube that was just lying in the exhaust hole. Does anyone first off have a diagram of this area of the motor and secondly know what this part is called so I can get it ordered. Thanks
eurolarva
Re: Plastic Tubing going to exhaust??
Try looking here. I am guessing you are talking about the motor leg. I did not see anything there other then an idle exhaust fitting. Good luck 125 HP Force 1989
