- Jul 7, 2010
- 15,130
Re: Planing a Bayliner Capri
A little correction on my part: you're not WAY underpowered, you're probably short about 20HP. A 70 on the back of that boat would make all the difference. Being on plane isn't your issue ... gettin' on plane is. You just need a bit more chutzpah to get you over the top.
You may want to pull your floor at some point and put some flotation foam in (have a look around the restoration forum), but if the rest of the boat is solid then you should be fine. Especially on the lakes and rivers in KY. Just be a little careful - I've been very impressed by the types of storms that pop up on the lakes here in TN. I've only been scared a few times out on the water, but one of them was during a pop-up storm here in TN on an impound. A couple of bad stringers and I woulda' been swimming to shore.
...So I'm not overly concerned about the 50hp. It's real close to coming up to plane now...
...You're just way underpowered on that boat...
