Piston Replacement on a Mercury 150 V6, Some Advice Needed
snowbrd84
Took the boat out this weekend for the first time with the new to me '86 Mercury 150 XR2. It seemed to be running great although there was some hesitation and every once in a while i would hear a strange clanking/knocking sound that I though was a misfire. The 150 on my 18' bowrider absolutely flew, scary fast. All of a sudden, horrible castostrophic banging/clanking sound at 3/4 throttle, kill the motor. Long story short, get it started back up and limp home with basically no power and it would die if given any throttle.
I start it up the next day and it seemed to run perfect, no sounds. Run compression check, 115-120 psi on 1 through 5, but then 0 on #6. Pull the head and found destroyed piston on #6, see below. So there is very very light scoring on the cylinder walls, can barely feel it with my finger and cant see it with the naked eye.
Here are my questions:
1) Since the scoring is so light, is there any way I can just hone it and throw in a new piston? It was scary fast with 5 cylinders, as long as it wouldnt cause it to fail again, does it absolutely have to be honed? I am out of budget at this point and cant really afford that shop bill...
2) What other things should I look for damage wise? I have most of the motor off and I will be pulling the power head tonight to crack it in half.
3) I am trying to figure out what caused this damage, it was not running hot and it definitely had oil. I did replace the stator and a switch box prior to taking it out. Could the stator or switchbox have caused detonation resulting in this?
4) Any general tips or suggestions on the piston replacement? I never replaced a piston before, but I have stumbled through a good deal of engine work. I do have the Seloc manual and I will be using that to assist.
Dukedog
Re: Piston Replacement on a Mercury 150 V6, Some Advice Needed
Don't like being tha one ta bring "bad" news but tha motor has ta come completely apart. That kinda damage put debris through out tha motor. Could have possibly got tha crank and some of tha bearings also. It also spreads to tha front half also. Inta tha reeds and reed blocks. A "hone" will not fix it............jmo
snowbrd84
There was a bunch of debri in the bottom of the reed block at the #6 cylinder and behind the #6 piston, but I didnt see any debri in any of the other cylinders. I guess I will know more once i crack it in half and can get a good look at the crank. Maybe I should just part this thing out instead if it is really that bad.
Dukedog
On tha "bright" side being a steel 2.0 motor and other holes are still good and crank not hurt (?) it can be fixed rather reasonably if you can do all but tha machine work..........Ya just need ta do some research on "cause" and what it will take in parts and machine work.......jmo
snowbrd84
As to the cause, I did some searching and one thing I can across it that Mercury recommended premium gas for these XR2 motors and that running regular unleaded could cause major detonation issues??? I definitely put regular unleaded in as I had no idea of this, had no clue... I see where some people say they run these with regular unleaded with no problems though. Is it possible running it with regular unleaded one time could cause detonation that would have resulted in the edges breaking off the piston???
wired247
To my knowledge Mercury didnt require anything more than 87 octane on those 150 HP 2.0 liter fishing motors.
Dukedog
NO.........
snowbrd84
I wouldnt think so. So I got the powerhead on the workbench and the crankcase cover removed. The lower end bearing ball bearings were reduced to small deformed metal chunks. There is a little damage to the crank case cover down at cylinder 6 from metal getting pressed into the crank case cover by the connecting rod im guessing. Is that going to matter? basically some gouges in the channel. Also, a couple of the crank shaft seal rings were broken in half and fell out when I cracked the case open.
I removed the piston and the connecting rod looks good. Feeling the inside of the cylinder wall, the scoring is so light that i cant feel it with my fingernail, but i can feel it with my finger. I think what I am looking at is the following:
1) Remove all pistons and crankshaft to clean out the block of any debri.
2) Hone #6 cylinder (should i hone all the cylinders?)
3) New piston and rings for #6
4) All new crank shaft seal rings
5) New lower end bearing
6) New upper end bearing
Dukedog
Really needs ta be checked for tolerances. Never had much luck with just a hone and replace. If ya do hone tha others do so very, very lightly. A hand held hone can destroy a cylinder in tha wrong and/or unskilled hands real quick. A "ball" hone is good but tha ports tear one up pretty quick.
Rod/rod cap needs ta "torqued" (not on tha crank) and checked for true before ya put it on tha new piston.
Just replace tha broken ones. Leave tha originals in place. Broken ones were probably done when ya pulled tha front half off. That's usually tha case. When replacin' tha two take sand paper and lightly take some of tha "sharp" edge off both sides of tha ring.
Double check crank runnin' surface.
Did this one show damage/metal particles? Here again double check crank runnin' surface. Especially this one.
Double check tha valve/bibs on top and bottom of front half. Tha ones that had tha small tube connecting them. Tha bottom is a one-way bib. tha top is both way.
On tha front half with tha damaged runner. Make sure there are absolutely no penetrations completely through it. If not make sure to debur any and all "marks" in tha runner where tha debris went thru tha motor.
Now ya gotta figure out which went first. Piston or bearing. I'd lean toward piston. Reason, 'cause tha top bearin' didn't go to. Top get its fuel/oil mix from tha bottom. Could be tha other way 'round just as easy though...........
I'm sure I missed something but its a start. GL....................
snowbrd84
Thanks Duke, appreciate all the advice. Upper end bearing looked fine, but all the rollers fell out when i pulled it off.
I think I may just bite the bullet and take the block to a machine shop to have the cylinder honed or bored. Im not sure if the bearing went first or the piston. Considering I was able to start it up the day after taking it out and it sounded fine, reved up with no bad sounds like the day before on the water, I am leaning towards this is the reason the guy sold the motor and just flat out lied to me. I think all that debri in the bottom of the motor was just sitting down there, and the motor would run until some of it started making contact, then all hell broke loose. It started up and ran so good after buying it, i didnt check compression, lesson learned....
Im planning on rebuilding the carbs and other various things.
Dukedog
All early 2.0 and 2.4's do that. Don't lose 'em. Clean 'em all up. A little grease and patience it goes back together..........
Very good idea. No sense doin' this again later on...................
snowbrd84
Well I pulled the crank and found this, ball bearing got slammed through...IMG_20130911_190311_525.jpg
snowbrd84
So is the block toast or can a shop fix that hole?
Faztbullet
Take to a marine shop as it can be welded but it will have to be machined so seal rings will have correct radius and surface.Get a estimate first as it maybe cheaper to get a block.
snowbrd84
the seal ring surface is unmarked, what you see in the pic is just some oily grit. All the damage is down in that race where the end of the crankshaft rotates. I cant afford a new block, every block i have found online costs more than just buying another used motor....
snowbrd84
Would I be out of my mind asking if this hole could be cleaned up and repaired with JB Weld??? Correct me if I am wrong, but where the hole is, it wouldnt be subject to pressure from compression and temps should be below 500 def f right? Just throwing it out there, because I am guessing a machine shop is going to want atleast a couple hundred bucks, which adding in the parts to fix the rest of the motor, it would no longer be feasible and I may as well just part out the motor...
Dukedog
Probably gonna get a lotta boo's n can't do that but......Ya can find a front half (probably e-bay or S&F) for really cheap. Any Merc/Mariner V6 VERTICAL reed front half will work. I've done this for years without a problem. You may need ta pull locating dowls outta tha block ta get tha right alignment. Some of these (probably all tha hot rods) I've turned way north of 9 grand so..........
If ya want I'll get on S&F and ask around. Might find a complete block for cheap. Tha early 2.0 stuff goes for next ta nothin'..If your not pressed for time...
Is tha crank hurt? If it is ya might as well through in tha towel........
snowbrd84
The front half really only has some very minor dings and can be cleaned up so I dont think that needs to be replaced, I wish this hole was on the front half, of course it had to be on the block side... Yeah let me know if you hear of anyone that has a block they want to sell. Like I said, problem is cost and then there's shipping. The lower unit on this motor is absolutely perfect, spin the prop and you cant hear a sound... If this block is going to cost too much to fix, I may just look for a 135 powerhead as I am pretty sure it will bolt right up. This 150, running without the #6 cylinder, was ridiculously fast on my boat, so a 135 would be more than enough...
Dukedog
That would be to tha better if ya have some way or one that can check out what your buyin'....There's a lotta "junk" out there. Just do your "homework" on anything.............GL with it.
