Pinion gear removal
Steviega
Hey guys,
I have a 1980 8 hp johnson that I'm trying to replace the lower unit gears on.
I have removed the shaft and first gear but cannot remove the pinion gear that will allow me to remove the back gear. any suggestions, thanks
Chinewalker
Re: Pinion gear removal
You need to pull the driveshaft out... requires removing the waterpump housing.
- Scott
Steviega
Thanks for your reply Chinewalker,
I've taken everything out of the foot except the pinion gear and the back gear. The pinion gear appears to be pressed in place. At least I've been
unable to remove it. There are nothing apparently holding it in place.
Chinewalker
If everything else is out, then the forward gear should pivot and it should slide under the pinion, allowing the pinion to drop down...
- Scott
Steviega
Thanks for your suggestions. I try again to get the gear out. here's a pic
Steviega
Mission accomplished. I used a tool that pries off paint can lids and popped it right out. Thanks for your help :D
