Perko Switch 8501 installation and operation...
YBW0S0
Someone said do not switch while runnig other said it does not matter well the owner manual said.........For use with alternators and generators rated 6-50 V.D.C. switch rating: 250 amperes continuous, 360 intermittent. Locate switch to keep battery cables short as possible. All wiring to the switch shall be preformed by a QUALIFIED MARINE ELECTRICIAN, and in accordance with the “Fire Protection Standard For Motor Craft”, N.F.P.A.* No. 302, The Standards of the American Boat and Yacht Council, Inc.*, and the U.S.C.G.* Safety Standards for Boat Electrical Systems (33 CFR 183). CAUTION: (1) Make sure connections at terminals No.1 and No. 2 are of the same polarity. (2) Always STOP engines before switching to “OFF” position. Make-Before-Break feature allows switching between 1-all-2 positions with running engines. Erratic operation, particularly after very long periods of idlen..........
poconojoe
It clearly states: "Always STOP engines before switching to OFF" and "allows switching between 1-all-2 positions with running engines"
So, why are you questioning the manufacturer's instructions?
Silvertip
Honorary Supreme Mariner
Make-before-break terminology means that the switch can be changed between 1, 2, and both with no issue. The switch setting in current use is not "broken" until the desired setting is "made". And as was mentioned in the literature, to avoid electrical damage do not set the switch to OFF with the engine running.
