Texasmark
Thread starter- Joined
- Dec 20, 2005
- 15,061
Don't know where this goes here or in OB discussions but this is a Merc Repair point:
Was in my service manual yesterday and looking at my engine and stumbled across something easy to overlook (I did......but I don't repair engines for a living and don't look in there that often).
In the wiring diagram they use color coding like "blk/yel" and also use "yel/blk".
When you are fiddling around in the engine and looking at wires, pay attention to which color is listed first in the wiring diagram. First is the wire basic color and the second is a stripe on it. Very easy to be looking for black and yellow colors and wind up on the wrong wire.
Like yel/blk is one wire and goes to the fuel enrichment valve.
Blk/yellow is 6 wires and go to the ignition modules.
HTH someone.
So, Willy or Silver or other mech, what does the black/yellow wire from the ignition switch to each module do? I assume it kills the module when you turn the key off, but what does it do inside the module?
Thanks,
Mark
HTH someone.
Thanks,
Mark
