Patch, then rebuild next winter?
Tim Frank
Re: Patch, then rebuild next winter?
When installing the new points, one of the copper retaining clips (secures the point set spring to the base) snapped off. New clips were not supplied with the new sets.
The points gapped properly and seem to operate normally without the clip. Does anyone know how necessary the clips are?
I wouldn't put the flywheel back on without it....
Tim Frank
Found two! :) Is 45 ft-lbs the correct torque for the flywheel nut?
Wait for confirmation, don't guess.
I don't have that motor HP or year, so my manuals won't help.
Windjamer
For follow-up information to all the great guys who posted to this thread, I changed the coils, points and condensers and torqued down the flywheel to about 43 ft-lb. (Spec is 40 to 45) It started right up. I then de-coked with Seafoam, as suggested above, and ran it a bit more in the shop. I installed it on the boat and ran at varying speeds around the bay behind my home. It idles well and seems smooth at WOT; a little rough in the mid-range.
I didn't check the spark, set the timing, or check compression before assembly because I didn't have the right equipment. I'll save that for when my brother-in-law moves to the community, as he has the necessaries. I've gone fishing about six times now, putting close to ten hours on the motor. It will idle and troll without stumbling or stalling, so I'm happy.
And to think, the dealer said it wasn't worth fixing! :)
Rick.
Way to go. Have a blast with it. Rick.
bonz_d
Too many reasons to list why he didn't want to work on it. Maybe he wanted to sell you a new one? No profit margin?
It's great to hear that you've got it going. I've got a 1969 Johnson 9.5 that just refuses to dye. Try a new set of plugs in it sense you've decarbed it with Seafoam.
