part finding help
dnpowers
1980 Johnson 70hp. Can anyone help me find the plastic/delrin/nylon bushings that go on the large pivot pin/pivot shaft that the motor pivots up and down on?
MTboatguy
Are you looking for the tilt tube bushings/washers, you might take a look through this link of images to see if you can find what you are looking for:
https://www.google.com/search?q=John...45%3B300%3B225
You might do a search on ebay to see if you can find a tilt tube rebuild kit also.
You might also take a look at this link, this is for a 7/8" system, but he also has separate prices listed for the different parts, might be work dropping him a note for your particular engine.
http://www.ebay.com/itm/TILT-TUBE-7...E-JOHNSON-321511-STT-1-20-50-HP-/131391586245
emdsapmgr
The swivel bracket tilts up and down with two bushings on the tilt tube. 321035. You may also need a pair of plastic thrust washers, part number 321036, which supercedes to 910992. Both p/n's In stock at the factory and available thru your Evinrude dealer. See the factory parts lists.
dnpowers
Thx guys, its the 321035. Anyone have a parts diagram for this area of the motor? I couldn't seem to find one.
emdsapmgr
You can go to the factory parts diagram website: epc.brp.com There are many sites with the same info around
kat-a-tonik
NAPA can order nearly any part you want for this motor, or atleast mine can
