I have repaired some deep gouges and scrapes on the bottom with marine tex. I plan on filling the minor ones with evercoat marine filler. Then paint over with gluvit. Then I will coat with interlux black anifouling paint. I need to know how I should go about it. Once I have all the scrapes filled in with either filler or marine tex I plan on sanding down with 120grit sand paper. Then clean with acetone and apply gluv it. After that I'm not sure how to go about painting the gluvit. I have bought interlux antifouling Paint, bottom prep cleaner, bottom primer, and the gluvit. Any tips or tricks for applying each would be appreciated also. Thanks for the help in advance.
