Painting my boat - primer down now
samm835
OK so last night i finished priming my boat(after a good sanding. I am only painting above the rub rail, so tonight i will do a light sanding and then get started painting. I have not ever painted a boat before.....so I am nervous as hell! I am using the roll and tip method. Here is my thinking, first tip all edges, corners and then roll the rest. Once it dries completly (over night) I will do a light wet sand, and then do the same process all over again for second coat. I know its not going to be perfect, but to be honest I do expect it to be dang close. I believe I bought the self leveling, so that should take out a majority of my "orange peel", but a thought that has been going through my head is.......the areas I have to use the brush, and then the areas I use the roller....will it be a huge noticable difference when in the sun light? Thanks any help would be great. I have read a ton of threads on painting.
MichaelP
Re: Painting my boat - primer down now
It's my understanding that after rolling the paint on you go back over it all lightly with a badger hair brush. The pros will be along shortly and will have questions i.e. Whats the hull made of, type of paint your using, what primer did you use etc.
I struggled with this myself but sprayed.
Woodonglass
Yep, type of paint and Roller and brushes is important. Let us know what you're using and we can guide you through it.
samm835
Rust.jpgI got the Rust-oleum top side paint and rust-oleum primer as well. Thanks
Woodonglass
Ok, I have used that a lot in the past. You can add a hardener to it if you want. Makes it a lot more durable. I prefer the Roll n' Roll method. Check the last link in my signature below. It has a lot of helpful details for you. Valspar and Rustoleum are almost identical paint so the methods are the same.
samm835
Thanks W.O.G., i have looked through a ton of your post.....all very helpfull! I must have missed it somewhere when i was reading. I have my rubrail taped, also anything i don't want painted airvent (unable to unscrew) also window sidings, so in areas where I can not get the roller.....and I have to use a brush, will their be a noticble difference between the two types of methods of paint? If I could I would spray, but 1) dont have one 2) I have no doubt I would screw it up more somehow. Thanks I will take pictures tonight before and after first coats.
