Hey guys
I am still prepping my boat ready for a complete new paint job, I think about another week of sanding and I might be ready. I am working on a fiberglass 18ft ring18 speedboat.
I am looking into the best way to re-paint the boat, and any steps that I should follow. I assume that I will need to use some sort of primer before painting anything, if this is correct, can somebody give me some information about primers. Is there much to know? Will any old primer work etc?
I see there is a method of tipping paint onto the surface, using a sponge roller to spread the paint, and then use a very fine brush to lightly go over the rolled area to remove any bubbles etc. This method looks quite quick and easy, which is appealing. However... As I am doing a complete re-paint, I need to also re-paint the underside of the boat, So, should I look at flipping the boat and using this method, or can paint simply be applied with a roller rather than tipped, and then gone over with a brush?
I don't mind spending a few beer tokens on a spraing system if it would make the job easier, or give a better finish. However, I do not have any indoor facility to spray the boat, so I am at the mercy of the great outdoors. I assume this may be a problem if spraying? Also, when using a spray gun, is it simply a case of just thinning the paint (to the suggested levels by on the tin I guess) and using a spray gun?
I would also love to add some graphics to the paint work, Something simple, maybe a single colour using a stencil / template. Would this be best done using a spray gun, or another method?
I have tried to do some research into painting, however I am confused by the many brands, and types of paint and don't really know what I should be looking at doing at the moment.
Any advice would be greatly welcomed
Cheers
Noodle
Cheers
Noodle
