Painting Johnson O/B hood?
ezmobee
Re: Painting Johnson O/B hood?
Jim, that gasket is called a "cowl seal". Might help you find it.
JimbC
Yup Found one ,But it's called Seal, Motor cover :D Not too bad $28.56
tmcalavy
Nice work...best way to protect it after you are finished is several coats of a compatible clear coat...let it dry/cure for several warm days...then put on a few coats of wax. Helps the oowie makers slide on past and protects your paint/decals from UV rays that can cause yellowing/fading.
Rudi2
"oowie makers" Tee-hee! I like that -- seems to be a lot of them going around! :)
