JimS123
- Jul 27, 2007
- 8,356
Re: painting an outboard
Gee its awful hard to troubleshoot remotely without seeing the job!
The primer should be "flat", as opposed to semi-gloss or gloss. It should however be smooth. "Sandy" I can't imagine. Does your topcoat finish look rougher over the primed spots as opposed to the previosly painted spots?
I don't have your paint can in front of me so I don't know what the recoat times are. But I would guess that you can't paint tomorrow, or even sand for that matter. Wait a week before you do anything. If you paint too soon you will bubble, blister and lift the paint and you will end up having to completely strip the motor and start from scratch. Whatever you do, don't put acetone on it n ow.
If you could take a closeup pic of the sandy spots and what you have now it would certainly help.
Well jim it's kinda hard to explain what going on because i have never done this before.So here is the best i can do and i hope you understand as i'm new to this.When i put the self etching primer on it had like a sandy look to it so i figured the paint would cover it up.Well thats not the case as it looks like sandy paint on it on not a smooth finish.
The only thing i think i can do is let it dry till tomorrow and sand down the paint one more time with like 800 or 1000 grit to smooth it out then clean with acetone then repaint one more time.Does this sound right.
I think if i sand down the paint a little it will come out much better.
