Painting a 14' bayliner capri..need suggestions
drewgoeke
I recently just arrived on the boating scene and i'm learning things a little at a time. I bought a 1986 bayliner capri this year and it needs some work but not alot. I plan on reupholstering and what not which I can figure out on my own. However, I would like to throw on a new coat of paint or change the color a bit and I was looking for some tips about what I should do.
1. Is there a special marine paint I should invest in? I actually thought about just covering with rhino liner but I decided that would probably look like crap.
2. Can I just paint over the original paint or do I need to prep the hull with sandpaper and what not?
3. What would be the best way to paint the hull? Roll the boat over? Or build a stantion of some sort to support the boat so I can get underneath it without the trailor.
If you have any tips that would be great!
mmccoy555
Re: Painting a 14' bayliner capri..need suggestions
Are you painting the bottom or the whole boat?
drewgoeke
I want to paint the outside hull first. The inside isnt bad, but the faded discoloration on the outside is driving me nuts.
mmccoy555
Everything has to be sanded for sure. You have to get off any loose paint and or get rid of the shiny surface for the paint to adhere to. If you want a nice professional looking job use Awlgrip/Awlcraft. It can be sprayed or rolled with a glass like finish. It does get pretty expensive for the material but the end result is worth it. Note that it is hard to work with though. Temp, mix, humidity all have to be perfect.
drewgoeke
Taken and noted. However, whats the best way to paint it, roll it over on its top or have it suspended in the air someway?
mmccoy555
Oh, it doesn't matter. Usually you don't want to roll a boat over at all. You can put it up on blocks to get the trailer out of the way or leave it right on the trailer. As a painter I have painted both ways. Never once rolled a boat over for it though. Am I making sense or am I misunderstanding what you are asking?
drewgoeke
You make total sense. Thanks for the help!
gcboat
The prep is the most important step. Bad prep, bad paint job.
In regards to mmccoy555 references to use the AwlGrip or AwlCraft products I'd avoid then like the plague if you're a beginner. Unless you're going to have a professional do it for you. The AwlCraft can only be applied by spraying - it cannot be used in a roll & tip method. The AwlGrip can.
I'd stick with a single part linear polyurethane such as Pettit's Easypoxy, or any of the Interlux top side enamels. Some folks have had excellent luck with Rustoleum - they also make a marine enamel.
Here's the link to the Interlux website. Lots of good info in there if you want.
http://www.yachtpaint.com/usa/
Remember: 90% prep - 10% paint . :D
sschefer
Paint, Paint, Paint, it's such a difficult subject to address. It seems the Boat Manufacturers get it right and cover a multitude of situations but when it comes to do-it-yourselfer's like us we are pummled with a ton of options, warnings and restrictions.
IMHO, the best bet is to call the manufacturers of the different paints and tell them what you want to achieve. They will tell you how to prep and apply to achieve the best results. From that you can narrow it down to what you're capable of both physically and monetarily.
As for the best position for the boat when painting. If you can flip it over this is definitely the best. Your choice of application methods broadens as well as your ability to clearly see the results of what your doing.
What did I use, Interlux Perfection and Interlux VC Performance 2 part epoxy. I think I also got course credits in mixology and chemistry as a bonus.
