Paint flaking on aluminum
pinner
About 3 years ago I painted my brothers 12' aluminum car topper, I cleaned prepped and applied grey etching primer that comes in rattle cans. The boat has been in storage since then. When I went to pick it up the paint is flaking off to the bare aluminum everywhere on the outside "which never had paint from the factory" but the paint on the inside of the boat "which had paint from the factory" seems fine.
So obviously the prepping I did to the outside was not sufficent, so im in the process of sanding off the remaing paint on the outside and starting over. My new process will be sand, 50/50 vinegar wash, prime with zinc chromate then top coat. So heres my questions for any that can answer.
How light of a coat do you put the zinc chromate primer on?
Should I lighty sand and zinc chromate primer the inside where the paint is not peeling, or just light sand and top coat?
Is the vinegar wash mopped on then rinsed with water?
Thanks
gcboat
Re: Paint flaking on aluminum
The zinc chromate is applied very lightly. Almost a 'heavy dusting' - .
The ole' vinegar trick is really not needed anymore. With the advent of all these etching chemical sprays, etc. it's a step that isn't needed. Not saying that you can't do it - just not necessary. And no, I wouldn't apply the zinc primer over sound paint. Just a good cleaning, some light sanding and do your top coat.
The zinc primer should have at least 24 hours to bond before applying your finish coat. Folks sometimes confuse bonding time with drying time - big difference.
ryanbriggs
hey there i have a 1958 lonestar holiday 16 ft. aluminum boat and i'm restoring it...... soooo a quick question wat is the best way to remove the old paint????
plzz help me
thanks
plzz help me
thanks
Ayuh,... Welcome Aboard,.... Start yer Own thread, insteada hy-jackin' some Antique.... July 5th, 2008
ryanbriggs
sorry about tht i'm new to this....got no clue about this forum..just tryn to get help on my boat!!!!
robert graham
Thanks
Have you considered just stripping off all that paint, then clean/polish your bare aluminum hull on the outside?...bare, shiny aluminum is very attractive, easy to clean...and no paint to peel!;)
jigngrub
If you do repaint be sure to watch your drying and recoat/cure times. A lot of spray paints have a "recoat within 1 hour or after 48 hrs", if this isn't followed the paint will lift and peel.
TTavenier3
plzz help me
thanks
:facepalm:
Aircraft Aluminum Cleaner. be safe wear gloves and breathing mask and glasses. :D
Bob_VT
Gentlemen This is a 4 year old thread that was opened in error by a new poster.
No more responses necessary unless it it from the original poster. The new poster will start his own thread.
ryanbriggs
Sorry bro didnt kn
