eavega
Thread starter- Joined
- Apr 29, 2008
- 1,377
Hey folks
I am in the process of fitting out a 1976 15' Yar Craft Yankee runabout for fishing on the lake. I got this hull as an alternative to doing a full transom/stringer/deck restore on the 15' Chaparral tri-hull I had purchased last year with the hopes of restoring. The new hull is essentially empty; no seats, no controls, no nothing. There was some hideous outdoor carpeting on the deck, but that was not even glued down. It is already bare fiberglass with no glue (or gelcoat I assume, since it doesn't have any tinting beyond being yellowed, and you can still clearly see the cloth pattern), or seat remnants, or anything. I didn't want to put carpeting down on the deck since I intend to use it mostly for fishing, and nasty things could get into the carpeting. I had instead thought of using topside paint with nonskid additive. With that in mind, I went to my local marine store to see what they had that would fit the bill. They had Interlux Interdeck nonskid paint. Will this do for painting the deck and keeping it nonskid? Will this end up being like walking on sandpaper? Also, in reading the label, I see that the only preparation it requires for use over clean fiberglass (I'll assume that means to wipe down with acetone)is to abraid with 180-220 grit sandpaper. does that mean it doesn't need any primer?
I really just want to do this right so that I don't have to do it again in a year. Any thoughts or suggestions would be appreciated.
Rgds
-Eric
Rgds
-Eric
