Xesvuli420
Thread starter- Joined
- Sep 20, 2009
- 144
Ok, so the boat over heats on plane...
I have replaced the entire impeller housing and pieces (Since I was told this was a yearly maintenance item anyways, figured it couldn't hurt). Not to say this is the overheating problem for sure, but the old one was all kinds of messed up, and not allowing the designed amount of water to pass. However here's what I'm wondering about...
Boat stays cool as long as its sunken in the water, but once on plane, it begins to heat. I have been told that "typically" this means that a connection, or hose, or something that is under water before planeing is sucking air once planed due to the water level dropping as the boat gets on top of the water...
On my old housing, there is a small hole. It looks like it was designed that way, but I'm not sure.
When I got the NEW impeller, housing, and cage, instead of a hole, it has a new piece on it, with a barbed end (See pictures) like for hooking up a line to it. I asked Sierra what this was, and they said it was to visually be able to see the pump is working. If water shoots out, then all is good. Sorry but this answer just doesn't make sense to me for a few reasons...
1. Since it is on the "SUCK" side of the impeller, won't the boat just suck air on plane instead of water (least resistance) if left uncapped, or unplugged, or whatever?
2. if its to be left alone, WHY IS IT BARBED?
We already know that the boat doesn't cool once on plain, could this be a reason? How about the fact that the cage had been turned to the point it was shutting off half of the water passages? weather it fixes it or not, it obviously needed replacing!
P.S. DO I HAVE THE IMPELLER GOING THE RIGHT WAY?
Here are you some pics...
Description and notes (Just in case)
Pic 1 = NEW impeller with Barb'd elbow
Pic 2 = OLD impeller with NO elbow (and small hole)
Pic 3 = Inside view of hole
Pic 4 = See its on the suck side, if air is allowed to enter, wouldn't that throw off the suction?
Pic 5 = NEW vs OLD (notice how the cage on the old has been twisted, and now blocking HALF of the water passages)
Thanks everyone!
Thanks everyone!
