wapitiguide
- Apr 21, 2012
- 25
I have two different questions. First took boat out yesterday and it overheated. The pipes going to and from the fresh water pump were cool to touch. The pipe going from the fresh water tank(???) to the exhaust manifold was very hot to the touch. It would cool right down to 180 degrees when running about 2800 rpms. It would heat up to about 250 at about 3500 rpms. Did not go above that and as soon as it got close to 250 I slowed her right down. Would this be an impellar problem, air leak problem or totally something else? Second question my throttle cable broke yesterday. AS I was changing it I must have broke one of the electrical wires that plugs into the controller. As I pulled the broken end off the part that the wires hook to slipped out. Now I don't know how to get it to go back in. Pictures would be great to show me how that is set up. Also thanks for all the help on my stalling problem. Replaced the new points with another set and changed the coil now it runs like a champ. Well minuse the new problems
