smassey22180
Thread starter- Joined
- Apr 15, 2013
- 210
I accidentally drained my battery by leaving the ignition on for a few days. I charged on my trickle charger for 12 hours and that got the battery to 11 volts and I was able to start the boat on muffs this morning (with hopes of going out). I then let the engine run at 1200 RPM for a few minutes to charge the battery. After 10 minutes I saw a little smoke in the (closed) engine compartment and determined it was coming from the alternator. Alternator case was 300 degrees. Belt was 120 so it was not the belt. I assume my little alternator was not able to charge my mostly dead 1000 cca battery.
I let everything cool off and the smoke did not return at idle with engine compartment open for air. Did I do any damage? Can I fully charge the battery and safely go out on the water tomorrow? Also which alternator do i have (pics attached)? Thanks to all for a great active forum!
