outdrive
Re: outdrive
Ayuh,... Post some pictures...
Don S
Re: outdrive
That's an AQ 280 outdrive.
dhallwhite
Re: outdrive
thanks this boat has not been in the water for a few years, but it has been garage kept. What do you suggest that I do before it goes in the water
dhallwhite
Re: outdrive
Ok thanks for the info. So, for my next question, should I summerize and then winterize or how should I proceed.
captmello
Re: outdrive
If you plan to use the boat, summerize it last, as draining and fogging the motor will not be necessary. :)
I would do a full tune up, and outdrive service. Both of which are covered in the winterization/sumerization threads.
If you have questions regarding specific tasks, feel free to post your questions. Starting a new thread for each task yields better results.
BTW, your drivetrain looks very clean.
Looks like your outdrive is tied up, get yourself one of these for towing.
http://www.ebay.com/itm/Volvo-Penta-Trailering-Bracket-270-280-Outdrive-/250886621966?pt=Boat_Parts_Accessories_Gear&hash=item3a6a020b0e&vxp=mtr&_uhb=1#ht_1310wt_76
