iconracing
Thread starter- Joined
- Jul 25, 2010
- 28
how do these work and are they worth it?
I think it depends on where you boat.
This guy is in Detroit. Def not needed up there where the water hardly ever hits 75degrees.
Here in CT nobody uses them at all. Then again we also struggle to get water temps of 70.
Now I was down in Palm Beach FL on a 30 ft boat and the water temp was 87or so. That might be reason to use them.
Why use a bilge pump? Hard to beat the simplicity of a couple of feet of 1/2" stainless tubing with some holes in it that you don't even need to drill a hole to install ....
I was thinking of something that would work at an idle as well.
Looked at my drive when we arrived and I could actually put my hand on the upper
I have an Alpha one, gen one with a Bravo type setup.To my knowledge (and I love beign corrected), the only real purpose for the drive shower is when you bypass the raw water intake through the drive with a through hull pickup. At that point, the raw water is being pulled through a running pickup in the hull near the stern and is connected to a seacock which should route through a seawater strainer to the engine.
When the impellor is drawing water through the drive, it keeps the drive cool as well. By passing the drive pickups requires an alternate means to keep the drive cool. One of the reasons you see it in a Bravo III more frequently is the BIII has the impellor on the motor, not in the lower unit, so it is easier to go with this type of configuration.
Otherwise, performance boats do use them as well due to the temps. generated at sustained high speeds.
first, i don't have one. but i've considered one. still am. looks pretty plain and simple to me for operation. they suck up water and divert it to on top of the drive. cooling it.
i've no idea if there worth it. i do know that i get hard water deposits on my drive after the water boils off. it leaves a white deposit on my drive. leads me to think that the drive is getting petty hot, likely when i'm on plane. a drive shower could help me out for the cooling it provides. on the other hand. if it's such a great idea, why didn't mercruiser put it out from the oem?
I have a thru hull water pickup that feeds an engine mounted raw water pump. I have no impeller in my Alpha one. It's my understanding the oil does the cooling, but I want a drive shower for the reasons you mention. However, i tend to believe the oil cools the drives as Mercruiser doesn't offer drive showers themselves.
These are all my own conclusions, and like you I love being corrected! Life is about learning from our mistakes and/or misconceptions.
You could very well be right. When i discussed options with my Mercruiser mechanic for going to a through hull pickup and bypassing the drive pickups his first comment was, "Sure, but you're going to need a drive shower if you want to do that".
My boat is wet slipped and my drive is painted with anti-fouing paint so I don't have any issues with deposits on the drive itself. While it's called a drive shower, I don't think it's meant to keep the drive clean, but I could be wrong.
