Outdrive Question
BigBK
I have a 1988 SeaRay Sundancer 5.7 L with Alpha 1 outdrive.
I spun the upper gears 10 miles off shore. replaced the outdrive with a new one. Only got to run it for about 14 hrs and tore the lower gears out of it.
I have no clue what could be causing this this to happen any help would be welcomed. Bob
backwater dawg
Re: Outdrive Question
Did you replace the entire drive or just the upper parts--gears only or the entire casing ??????????
dubs283
oh, sterndrive engineering.
i have heard some horror stories about warranty with them, i have never dealt with them but there is a reason their drives are cheaper than others
BigBK
I think i may have found out the hard way. i was hopeing it was just a bad outdrive rather than some other problem causing the outdrive to mess up.
Would still like any imput on this subject
BigBK
Well i got back on the water today. I had my old outdrive laying around for parts so i took the lower unit off drained and cleaned it out.
I installed it on the new upper and hoped it would work. and it did.
Took it to the lake and ran it for 2 hrs and it ran just fine. was a little afraid to WOT it so i kept it around 3600 rpms doing 34 mph. i figure that will be ok for now beings i leave for the ocean on Sunday morn for a week to fish.
Just wanted to update and thank all for the imput its a great place for finding a cure for your boats illness. thank you all. Bob
Bt Doctur
They will stand by their warrenty, When you filled it with gear lube from the bottom ,did you let it stand 24 hrs and then recheck it?
BigBK
Yes i did then topped it off. i have no warrenty anymore.
When i lost the upper i parked the boat, bought the new outdrive and installed.
Then boat sat for a year, so i have no recourse. Its out of warrenty
Bt Doctur
Warranty changed to 3 years, might want to contact them and see
