Outdrive oil in bilge
jamesr1
I know I have read about this before, but can not seem to find it using the search funtion.
If I remember correctly there are seals in the upper drive case that will allow lube to come in through the drive bellows and gimble. Is that right ?
This is a Alpha Gen 2 drive. Thanks...
Don S
Re: Outdrive oil in bilge
You are remembering correctly. The input shaft seal is leaking.
