Outdrive leg?
boatallsummer
When a boat needs an outdrive leg what does this mean? Is it an expensive fix? A hard fix?
Don S
Re: Outdrive leg?
Leg usually refers to the outdrive. Many call the outdrive a leg, but never heard the drive referred to as an outdrive leg.
Don S
Re: Outdrive leg?
Instead of these wierd questions, why don't you just tell us what drive you have and what the problem is.
You wouldn't believe how many different models of drives Volvo has.
boatallsummer
Re: Outdrive
Re: Outdrive
Sorry, it was a boat ad I was referring to. I just wanted to get an idea of the price/complexity of the issue before I went to look at the boat.
I am looking at the boat at 5pm. I will have pictures, and more info this evening.
This will be the second boat I am going to look at the first had a Mercruiser 470 which I didn't feel like messing with. I am continuing to look at boats in ads just in case I come across a good find. Not counting on anything though, but who knows without trying! :)
Thank you!
Don S
Re: Outdrive
Re: Outdrive
All drives are expensive (some more than other) and all are difficult to rebuild if you don't have the special tools.
Gary H NC
Re: Outdrive leg?
Boat shopping again...At least we talked him out of that 470 boat he was looking at.
Is this one missing the drive or just not working?
boatallsummer
Re: Outdrive leg?
The outdrive is seized up due to being left in the water. It is an OMC 3.0L 4 cylinder. It has a rebuilt starter, alternator. The boat was fired up 2 months ago, and ran well. The husband is in FL, and will be back tomorrow. I talked with the wife. She said the motor was loud, had no smoke, and ran well when started.
The boat is a 1986 Bayliner Capri with an Escort galvanized trailer with new tires. The boat is in good shape. It has been covered with a cover, and under a carport. It has a fiberglass floor. The carpet is in good condition. The seats will beed to be upholstered. They have small cracks in them. They said the boat was 18 in the ad.
It needs a thermostat housing too. They want $700 for the boat, and seem like really nice people who lived in a nice neighborhood. They have another boat that they use, and don't want this one. They specified they want it to go to a nice family who will appreciate it.
They said fixed up it could be worth $4,500. Does that sound right? I didn't think they were worth more than $3,000 fixed up. Not that it matters too much as no plans for resale right now. It matters in terms that I don't want to put more money into it than what it is worth.
I haven't bought it yet. The husband said he knew a boat shop close to me that had the part for $500. He said it was cheaper now due to it being winter. The man seemed to know what he was talking about when it came to the boat, but he is the seller who wants to sell it.
Now about the outdrive. I have the model number as I took a pic of it. Are there any outdrives that are interchangeable from different engines? What are some special tools that are required to put a new outdrive on?
As always appreciate everyone's honest opinions as you taught me to run from the 470.
EDITED : to add this is the exact boat that I saw today
http://tinyurl.com/ycqpc7e
The seats are cracked, and the carpet looks like it needs a cleaning. The carpet is just dirty in a few spots not bad.
Don S
Re: Outdrive leg?
The picture you linked to is a Volvo drive, yet you say a 3.0L OMC.
What is it really?
Don S
Re: Outdrive leg?
Geeeez I looked at the small picture and it looked like an OMC stringer. Didn't wait long enough for the full picture to load. Then I went back and edited my post ....... TOO LATE. You already read it.
Anyway, I did edit my other post, so read it now.
HT32BSX115
Re: Outdrive leg?
Ok,
You're looking for a boat.
You have already ruled out a couple of engine/drive combinations that you should stay away from.
I'll say right now, that you should probably avoid any OMC, any Old Volvo (Don can tell how old) and any Mercruiser older than about 1980 or so.
Actually, you should probably only consider Volvo or Mercruiser powered boats from about 1995 on and you'll probably be just fine.
Avoid all the rest. Unless you want an outboard......if you want an outboard, ask in the outboard area....
Cheers,
Rick
boatallsummer
Re: Outdrive leg?
Now I'm confused as to what motor this boat has......
It says on a silver tag OMC Drive Systems
Mod. No. 985286
Ser. No. T0103236
I have been looking all over the internet for the past 30 min seeing if I could find it on my own, but couldn't.
Don S
Re: Outdrive leg?
Those are OMC numbers. You know why you can't find much info on them? They went out of buisness over 10 years ago.
I guess I should have left my original post............
Keep running Forrest.
CheapboatKev
Re: Outdrive leg?
Ok...You are shopping for a boat to get you out on the water all summer huh?
Glad you sterred away from that 470...Now you are looking at an OMC equipted boat...
Kinda out of the frying pan and into the fire my friend...
An OMC boat would be a WORSE choice than the dreaded 470..
OMC has been out of biz a looong time, not many if any shops have the skilled old timers that either know how or WILL work on em...
Is your heart set on an I/O boat, if so why? It is not just a car engine that you can wrench on, trust me...
Seems like this will be your first boat...Thats great, but I am thinking maybe an outboard may be the ticket for you..
Good luck...
ENSIGN
Re: Outdrive leg?
Sounds like it's just what you need,ANOTHER BAG OF WORMS!!!
Re: Outdrive leg?
Ayuh,... Especially when it's in a 24 Year Old Bilgeliner....
Don S
Re: Outdrive leg?
I think the phase is "Can of worms".
It's now a reusable bag, better for the enviornment than an old rusty tin can to be thrown on the ground when finished. :rolleyes: :rolleyes:
