Outdrive Identification help
rebars1
The out drive on my project boat is labelled "ALPHA 1"
ID # OD554000. The GBM said he thought is was about a 1994. Some listings show it a Gen II, but others do not. Can some please clairfy this for me? Or more importantly, which manual and/or water pump/impeller kit to get?
Don S
Re: Outdrive Identification help
It's an Alpha I, 1990. Had it been a 94 it would have been an Alpha I Gen II, and it is not.
rebars1
Thanks, DonS. The Mercstuff list shows Alpha One Gen ll numbers ranging from OD469859 thru OF679999 for 1990-1995, and the Alpha One being 6225577 thru OD469828 for 1983-1990.
Since my drive is OD554000, would not it be a Gen ll? Or is this list not correct?
Is the water pump/impeller kit the same for both?
Don S
Then just look at the drive, is it a Alpha I or an Alpha I Gen II
A Gen II drive has thru bolts and nuts in location a in the picture belowl.
Nope,...... 2 Very Different pumps..........
This is a Gen II....
This is an Alpha1...
Notice the Difference in how the Bolts look between the Upper,+ Lower Units......
rebars1
DonS: You are correct. Based on the skeg shape and bolts, it is an Alpha One.
Thanks also Bondo.
Is it OK to tilt the OD up a bit to remove the lower unit? Mine hangs too close to the ground to drop it much.
