Outdrive id help
slim6969
Hey every one I have a 1989 19’ tempest with a 4.3l and alpha1 drive.
im replacing the engine and want to replace the water pump and gaskets in the outdrive
the problem I’m having is the spot where the serial number should be has been wore off
behind it is a number but I’m not sure if that the right number or not
is there any other place I can find this number ?
here’s a pick of wheee the serial number should be and the number behind it
slim6969
[No message]
Ayuh,..... All the Alpha 1 water pumps are the same, 'n I use the Gen.II gasket sets for boltin' All of the alpha series drives back on, MC-1, Alpha 1s, 'n the Gen.IIs,.....
slim6969
Thanks for the reply’s Very much appreciated
