rockstar55667
Thread starter- Joined
- Sep 20, 2008
- 44
I recently bought a whaler 13 with a 1984 Johnson 35 on it. I just (3 days ago) paid $971 to get the head gasket and water pump replaced. (on a side note, does this seem high? the mechanic claimed the screws were hard to get out, thus the high price) Now the starter is shot. I also can not pull start the motor and keep it running. It will run for a few seconds then die, and the primer bulb goes soft. The remote throttle also needs some work too (the insides are kind of messed up, but it still works). The mounts also need to be replaced, because when the motor idles or runs it wobbles about.
My question is, is this motor worth fixing? I'm kicking myself now for spending $1000 on the head gasket and water pump. But I was told that this is all I would need to get her going for a long time. Should I cut my losses there and get a new motor?
New motors are around $5500-6000, does that normally include the remote throttle? I'm looking at Yamaha motors, as I've had a small one that has never let me down, and I continue to hear good things about them.
Any advice would be appreciated.
Thanks
Thanks
