Outboard Oil ratio Question
zippy83
Hi All,
I have an 2 stroke 50HP outboard that uses 50:1 ratio. I am planning in the coming weeks a bigger fishing trip and have a question about how much 2 Stroke oil I should put in 5 Gallons. I have a 12 gallon tank but the 5 Gallons are just for in case I start running low.
The chart says the following as you may already know
1GAL = 3oz
3GAL = 8oz
6GAL = 16oz
12GAL = 32oz
So I am confused on how much OIL I need to put on 5 GAL. If one GaL takes 3 OZ then 5 GAL should take 15oz but then again 6GAL takes 16oz...
How should I calculate this correctly
Thanks
Zipp
Don Hansen
Re: Outboard Oil ratio Question
Actually, they are rounding off the numbers. 50 to 1 for 1 gallon would be 2.56 oz. If you multiply 2.56 by 5 you get 12.8 0z. Just out of curiosity, 2.56 times 6 equals 15.36. Looks like they want to play it safe. Rather have the ratio rich than lean.
Personally, I always add an ounce or 2 extra when mixing up 6 gallons for my 1980 and 1974 motors.
DLH
GA_Boater
Go to K-Mart and buy a 3 buck oil measuring bottle. There are other places that sell them. Simple to use. If you put 5 gallons of gas in the tank, pour the oil in the bottle to the 50:1 5 gal. mark and dump it in the tank.
zippy83
DLH
I am also running a 1974 Merc Outboard. So on 5 Gallons I can safely add 13 - 14oz of oil?
zippy83
So it is ok to put a little more oil then expected?
GA_Boater
If you want to, but why? The motor is designed to run at 50:1. In my opinion adding extra is a waste of oil. An extra ounce or two of oil won't stop a motor from blowing up if it's already on it's last legs.
zippy83
I wasn't sure about it that is why I asked. So I guess 13oz on 5gal should do the job just right....
JB
Your outboard will run fine on anything from 24:1 to 50:1. It is just with more than required you get more smoke, stink and carbon deposits.
Oiling outboard fuel is like watering a horse; More than required is okay. Less than required is possibly fatal.
zippy83
Thank you
ondarvr
Switch to metric......:)
Metric is very easy, it's just hard to find a metric gas pump, unless you go to Canada, there are a few metric gas cans out there though.
The easiest way is to use %, 50:1 is 2%
128 oz (1 gallon) X 2% = 2.56 oz
I just use the bottle GA recommended, I try to save what little brain power I have to out smart fish.
GA_Boater
Maybe I better get another bottle cause it's not workin' for me. LOL.
I just add whole gallons of gas or is that whole 3.78541178 litres and go to the mark and dump. I like simple things for simple solutions. :)
pootnic
I actually thought I`d get more comments.
Then the one I do get is very civil,plus it gives an excellent solution...2% rule,nice.
Disappointing...)
Grub54891
I've always called it 3oz per gallon,never toasted one yet,not smokin either....
Grub
GA_Boater
Disappointing...)
Why? No matter how the gas is delivered, you still have to measure the oil. If I was getting gas in liters, I would get a metric bottle. Metric or U.S. liquid doesn't make much difference.
pootnic
Statement may be true...but
Up here most(all ?) of our oil bottles are measured off in ml's.Also,on the back of most bottles,they give common ratios(25:1;40:1 50:1 etc),for regular used increments.
To figure it out is pretty simple though;I just take the amount of liters, times it by 20 (or 2 and add a 0)...and that's how much oil to add in ml's.(really just 2%)
Most times I add the oil in at home,say 200ml's and then add 10L's gas.(then top of the truck with whatever)
In your case 5 gal's x 3.78 = 18.9 L's x 20 = 378ml....somewhere in the 350/400ml range depending how often I've been running my outboard,is what I'd add.
If I use the x's 2 method;I'd use 19L's doubled is 38,add a 0 to the 38...so 380ml.
Anyways,I was just messing a bit...you have some good advise for gallons...
GA_Boater
All of our quart bottles of TC-W3 have ounce marks with a semi-clear stripe. I worry about the accuracy using them. But it's probably "close enough".
Don Hansen
That's why I add an ounce or two from another bottle. I don't measure that extra bit, I just add it.
DLH
Scubaslife
3 oz. per gallon is a good general rule. It won't kill your motor is you're a little high but it could run hot and potentially cause damage if you're low. So it's a safe bet to round up.
