Omineca
Thread starter- Joined
- Aug 22, 2021
- 60
I have a 1984 Starcraft Islander 191V with a Tohatsu 9.8 4-stroke kicker. I inherited the whole setup from the Previous Owner. Due to Covid and teething problems we have only just got her going, and in a recent visit to a shallow rocky shore I wanted to put her on a shallow water setting/angle.
I am not an observant or boat-knowledgable person, to say the least, and it took me a while to realise that the outboard, though vertical, is already in the shallow position. As the picture shows, the heavy block that the cantilevered OB mount bolts to runs parallel to the transom, so is tipped back considerably from the vertical. Also, as you can see, the OB mount is in its highest position, but the OB leg is as deep in the water as it needs to be for running. There was no way I could get it shallower in the water.
What do I need to do? Is it a matter of relocating the mounting block higher, and possibly cutting it to form a wedge? Is there anything I can do with the cantilevered mount? Is the mount wrongly assembled or is there some angle adjustment I could make on it?
Thanks in advance for any advice.
